Vieux 15/07/2017, 22h29
raed83300
Avatar de raed83300
Pouvoir de réputation: 36
raed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond repute
Jai eu un cas similaire ton telecodage lors de mon premier bsi il faut pas faire ok lors du codage mais il faut faire retour
Codage vin puis sa suis tout seul codage calculateur present puit option client , code pin enfin codage clé.
Envoyé de mon SM-G920F en utilisant Tapatalk
Si je t'apporte mon aide n'oubli pas le bouton thanks
raed83300 est déconnecté   Réponse avec citation
The Following User Says Thank You to raed83300 For This Useful Post:
mindouza (15/07/2017)
