Vieux 19/07/2017, 20h43
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Small Box, cannot continue DiagBox installation (Solution)
A number of users met an issue where DiagBox shows a small box on the top left corner of the screen, where they cannot continue the installation.
This seems to be authorisation related which does not happen with Windows XP, and there are two ways to overcome this issue:
1- By renaming the Windows user name, then log out and re-log in with the user name or
2- By creating another Windows user (Administrator), where you log into it to continue the installation.
A Video showing DiagBox installation stuck at the described stage:
https://www.youtube.com/watch?v=UgygcCWfm_s
The shown installation was created under user "DiagBox", there were other Windows test installations created on the system with the same user name, which seems to be the cause of the issue. Hence, another user "DBox" was created to demonstrate that the installation will work and the reason is most likely to be confused authorisation.
Type de fichier : jpg DiagBox.jpg (56,6 Ko, 22 affichages)
Simple est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Simple For This Useful Post:
adiago (19/07/2017), guyguy307 (19/07/2017)
