Vieux 20/07/2017, 14h00
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut DiagBox Firmware: Appli 8.3.5 + BT 1.2.4
The software provided is intended for personal, educational and experimental use; to help with DiagBox installations and XS Evolution VCI communication. I hold no responsibility for any illegal or improper usage or any damage to your system. Carry out upgrade at your own risk.
For those interested in experimenting with the different DiagBox firmware versions, I have attached the latest (to-date) Application (Appli.com 4.3.5, DiagBox v8.45) and Blue Tooth (1.2.4, DiagBox v8.43) Firmware.
I have also included the older BT firmware (1.2.3, DiagBox v8.30) as it includes the HEX file, in case someone needs it.
Simple..
Type de fichier : zip App+BT_Firmware.zip (380,6 Ko, 216 affichages)
Simple est déconnecté   Réponse avec citation
The Following 34 Users Say Thank You to Simple For This Useful Post:
2009mohrice (20/07/2017), abdel93 (25/12/2017), adiago (20/07/2017), alsacien (28/08/2017), autodiagauto (28/09/2017), bebert1234 (22/10/2017), bej 974 (21/07/2017), Bllinda (18/06/2024), DIAGAUTO33 (20/07/2017), didi_du_93000 (27/04/2018), djslowrnb (26/09/2017), ecutech (20/07/2017), elie (12/11/2017), foulques (20/07/2017), guyguy307 (20/07/2017), hichamdz128 (27/01/2018), Ian995 (14/11/2018), jerome110383 (28/09/2017), Nextrick (02/10/2017), nounour10 (10/01/2020), octave (04/08/2017), Redha-TE (29/01/2019), REDZONE31 (20/07/2017), Roturbo (29/08/2017), samii1955 (21/07/2017), sivestiano (24/09/2019), tatel (02/02/2018), taxi5114 (30/09/2017), tony60 (20/07/2017), youcef_trik (02/10/2017), yoyomartin2003 (22/07/2017), yvespapou (20/07/2017), zagor (09/02/2018), zenata (27/09/2017)
