Vieux 21/07/2017, 19h28
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 updates 8.47-8.50 (DiagBox v8.50)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
APP_Update_847-850.exe update should only be attempted if you have a working DiagBox v07.847.
Link is provided in the attachment for "APP_Update_847-850.exe". This is intended to update Lexia and PP2000 components of DiagBox 8.47 to 8.50. The versions of Lexia and PP2000 will remain 500.74 and 600.80 respectively.
Procedure:
1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all associated processes to enable overwriting without conflicts.
3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
Done..! you may run DiagBox as usual.. Notice that DiagBox version will change to 07.850 after the update..
Have fun!
Lexia language is set to English and PP2000 to french, if you wish to change them, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa.
P.S. DiagBox has been running on Firmware 4.3.5 since 8.45.
Regards, Simple.
Type de fichier : txt APP_Update_847-850.txt (853 octets, 204 affichages)
Simple est connecté maintenant   Réponse avec citation
The Following 27 Users Say Thank You to Simple For This Useful Post:
abdel93 (25/09/2017), adiago (21/07/2017), calculat 39 (27/08/2017), DIAGAUTO33 (21/07/2017), didi_du_93000 (27/04/2018), elie (01/10/2017), fabien1506 (07/09/2017), guyguy307 (21/07/2017), hamza-elhadi (21/07/2017), jardini (08/09/2017), kam306 (22/07/2017), kitty-hawk (12/11/2017), lazizouille (21/01/2018), mahfoud lichani (28/08/2017), maskcoto (27/08/2017), megars (22/07/2017), mike3021 (01/11/2023), omarzoro (28/08/2017), Roturbo (31/08/2017), samii1955 (27/07/2017), scanflo (21/07/2017), Shadows93 (28/07/2017), tatel (02/02/2018), taxi5114 (13/11/2017), tlucent (20/07/2021), xavi5757 (25/05/2020), zagor (09/02/2018)
