Vieux 24/08/2017, 20h44
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Just for all to know, it was the ACTIA Drivers on Windows that did not recognize the VCI. So a reinstall did the trick.
@omarzoro,
I told you in a post on the other forum this:
https://www.lesamisdudiag.com/diagbo...tml#post211605
Salam omarzoro,
The Firmware you installed on your VCI should work, if you can communicate with the VCI then uninstall the Drivers and reinstall them. I think it is accidental that it did not work and the problem may be in a connection.
On August 21st.. You see why sometimes we get fed up because the user does not feedback properly..
Simple est déconnecté
The Following 2 Users Say Thank You to Simple For This Useful Post:
omarzoro (29/08/2017), Pilouf (25/08/2017)
