Vieux 25/08/2017, 16h59
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
If you have DiagBox installed on a Virtual Machine (VirtualBox or VMWare), copy the whole folder that has the installation, and place it where ever you want, then double click on the VMX file, it will load, if the VM ask you is this moved or copied, answer moved.
DO NOT create a clone the VM installation. If you clone it it will change the Windows UUID, and DiagBox will need reactivation, the original APPDIAG.SYS will NOT work in this case.
Simple est déconnecté   Réponse avec citation
