Vieux 02/09/2017, 16h43
omarino
Avatar de omarino
omarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to all
Par défaut audi A3 2l année 2007
j'ai une audi A3 année 2007 qui ne veut pas démarrer (le démarreur ne tourne pas). batterie et démarreur neufs.
j'ai fait in diag avec vcds, et voila les modules avec les codes défauts
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 4346
Revision: --H42--- Serial number: AUX7Z0G0FNF0H0
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 6ED328337962DE6E76F-803B
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006786
Shop #: WSC 06314 000 00000
VCID: 73E539471240F386991-8026
1 Fault Found:
01309 - Power Steering Control Module (J500)
008 - Implausible Signal
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Shop #: WSC 40050 146 51661
VCID: 4189A38F187C1116DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
01301 - Control Module for Voice Recognition (J507)
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106C1302C3
Coding: 7D3F574A07002102
VCID: 2F6DF537BEE897663D9-807A
1 Fault Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 224526 km
Time Indication: 0
Date: 2017.09.02
Time: 14:28:45
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 931 HW: 8P0 920 931
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: AUX7Z0G0FNF0H0
Shop #: WSC 00000 000 00000
VCID: F0EFB64BE356489EE43-80A5
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 H
Component: KSG H08 0070
Coding: 9880202002186D098505488F0077
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Component: Tuer-SG 020 0090
Coding: 0000248
2 Faults Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
00940 - Mirror Adjust Motor; Passenger Side (V150)
vue les nombre de defaults je ne sais pas qui me bloque.
Merci de votre aide
cdlt
omarino est déconnecté   Réponse avec citation
