Vieux 02/01/2012, 13h18
ABDARAHMENE
Avatar de ABDARAHMENE
ABDARAHMENE is an unknown quantity at this point
MOTEUR 1Z , ET C EST APPARAMMENT UN PROBLEME ELECTRIQUE. J AI TOUS LES SCHEMA ELECTRIQUE. J AI EN TENSION BATERIE SEUL 12,50 V EN TENSION ALTERNATEUR SEUL 14V ET UNE FOIS BRANCHER J AI PLUS DE 16V .J AI FAIT UNE VALISE AVEC VAG COM J AI 4 DEFAUT APPARENT DONT CALCULATEUR DEFECTUEUX. APRES UN RAZ J AI PLUS RIEN MM APRES AVOIR ROULEE AVEC LA VOITURE.
3 Faults Found:
00527 - Intake Manifold Temperature Sensor (G72)
30-00 - Open or Short to B+
65535 - Internal Control Module Memory Error
00-00 - -
01117 - Generator Terminal DF Load Signal
27-00 - Implausible Signal
ABDARAHMENE est déconnecté   Réponse avec citation
