Vieux 04/10/2017, 12h46
zenata
Avatar de zenata
Pouvoir de réputation: 174
bonjour julien34560
VW POLO 6Q0 907 379 AC ABS Pump
VW Polo 9N
Address 03: ABS Brakes
Controller: 6Q0 907 379 AC
Component: ABS 8.0 front H03 0002
Coding: 0000145
ALTERNATIVE ABS MODULE CODING
NB! These are the codings I currently have but are certainly not the only ones use by Volkswagen, SEAT, Skoda and Audi. As I get them I will update this list.
6Q0 907 379 - Coding: 00036 or 00044
6Q0 907 379 AA - Coding: 0000005 or 0000008
6Q0 907 379 AB - Coding: 0000005 or 0000008
6Q0 907 379 AC - Coding: 0000145 or 0000142
6Q0 907 379 AF - Coding: 0002061 or 0002079 or 0002082 or 0002085 or 0002103 or 0002115 or 0002118 or 0002122 or 0002136 or 0002145 or 0002175 or 0002181 or 0002190 or 0002193 or 0002199 or 0002202
As can be seen above, AF suffix has the whole gamut of codings and each should be tried before throwing in the towel.
6Q0 907 379 AG - Coding: 0002202 or 0002229 or 0002238
6Q0 907 379 AH - Coding: 0000299 or 0000284
6Q0 907 379 AQ - Coding: 0002356
6Q0 907 379 AS - Coding: 0002347 or 0002368 or 0002368 or 0002491
6Q0 907 379 AT - Coding: 0000269
6Q0 907 379 BC - Coding: 0002136 or 0002098
6Q0 907 379 C - Coding: 00044
6Q0 907 379 D - Coding: 00124 or 00188
6Q0 907 379 E - Coding: 0001097
6Q0 907 379 G - Coding: 00044 or 00045
6Q0 907 379 H - Coding: 00188
6Q0 907 379 L - Coding: 0001097
6Q0 907 379 M - Coding: 0000000
6Q0 907 379 R - Coding: 0000008
6Q0 907 379 T - Coding: 0000281 or 0000296 or 0000299
---------- Post added at 10h46 ---------- Previous post was at 10h41 ----------
re
Volkswagen:- (VW) Polo (6N/6N2 chassis) 1994 - 2002 and newer
Volkswagen:- (VW) Polo (9N chassis) 2002 -2010
ABS
Adaptation access MK60 = 00212
Adaptation access NDBW = 01025
Adaptation access DBW = 04097
Adaptation access SPECIAL A6 = 09399
Adaptation access FWD = 13204
Adaptation access AWD = 13504
Adaptation access AWD ESP = 18446
Adaptation access MK60 = 19469
Adaptation access FWD ESP = 23049
Adaptation access General = 27861
Adaptation access to basic settings = 40168
The Following 4 Users Say Thank You to zenata For This Useful Post:
Auto16 (14/11/2023), julien34560 (06/01/2018), prodiag2017 (23/01/2018), youcef_trik (05/03/2018)
