Discussion: DS3 problême bizarre
Vieux 04/10/2017, 19h29
alchemist974
Avatar de alchemist974
alchemist974 has a spectacular aura aboutalchemist974 has a spectacular aura about
Peut etre que tu l'as déjà réaliser mais je rajoute au cas ou
La procédure PSA - Réinitialisation BSI
- tout éteindre , ouvrir la porte conducteur ( porte passager sur 807/C8 ) et attendre 3 minutes jusqu'à entendre un clac de relais au niveau du BSI" car les 3 minutes sont plus ou moins fluctuantes...
- débrancher la batterie
- attendre 5 minutes
- rebrancher la batterie sans rien toucher d'autre (ne pas mettre le contact)
- attendre 2 minutes
- mettre le contact et vérifier le fonctionnement
(vous aurez peut être besoin de réinitialiser les vitres, il faut les remonter jusqu'aux butées pour l'apprentissage)
Peugeot BSi reboot procedure
Some of you will have already come across a strange problem when programming
keys on 2002 onwards Bsi equipped Peugeot. This usually presents
itself as a complete instrument cluster failure after the keys have
been programmed when the customer comes to collect the car.
BSI Unit
The BSI unit is basically a computer which
handles a multitude of functions such as
odometer value, central locking, lights and
immobiliser. Some later Bsi units are liable
to corrupt their own software program if
not “woken up” in a specific way after
programming keys or battery disconnection.
The details of this are explored
thoroughly in a Peugeot TSB but I will
summarise for you briefly.
Procedure for Initialising the BSI after key learning
1. Disconnect the diagnostic tool.
2. Put the driver’s window down, lift the bonnet and ensure all
equipment is switched off.
3. Ensure all doors are and remove key from the
ignition.
4. Wait for 3 minutes, disconnect the vehicle battery and wait
15 seconds.
5. Reconnect the vehicle battery, wait a further 10 seconds (do
not open doors.)
6. Switch on the side lights through the driver's window.
7. Switch on the ignition and check system’s functionality.
8. Hold lock button on key down for 10 seconds.
9.remove key open & close door test central locking system
10. Start the engine and complete the system’s check.
Failure to follow this procedure could result in incorrect operation of many
BSI related items.
It did take three attempts following this procedure before it worked.
alchemist974 est déconnecté   Réponse avec citation
The Following User Says Thank You to alchemist974 For This Useful Post:
VroumVroum (04/10/2017)
