Discussion: Immo off edc16c3
Vieux 07/11/2017, 16h57
AOUN
Avatar de AOUN
AOUN has a spectacular aura aboutAOUN has a spectacular aura about
Virgin won't help. Key working but sometimes cannot start. Customer's request need remove...
The below is instruction. It's not mine but from other forum so it is definetely works. Don't have lexia yet so cannot check.
Preparation with PP2000:
0. Go to replacement parts->injection->injectors-> print screen the injector codes
0.5 Go to engine ecu->configuration -> print screen the configuration
The cooking recipe:
1. Read eeprom with BDM (2kb size!)
2. Make virgin with ImmoDec 3.2
3. Disable immo on the virgin file with Immo tool v1.5
4. Load the eeprom file with BDM
5. With PP2000 go to ecu->confiuguration (notice all settings are virgin), do the correct configuration
6. Go to replacement parts->Injection->injectors , register the injector codes
If I helped, please, use magic buttons reputation+thanks
AOUN est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to AOUN For This Useful Post:
amine08 (22/03/2018), eescham (14/11/2017)
