Discussion: Immo off edc16c3
Vieux 07/11/2017, 17h25
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 26
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Envoyé par AOUN Voir le message
Virgin won't help. Key working but sometimes cannot start. Customer's request need remove...
The below is instruction. It's not mine but from other forum so it is definetely works. Don't have lexia yet so cannot check.
Preparation with PP2000:
0. Go to replacement parts->injection->injectors-> print screen the injector codes
0.5 Go to engine ecu->configuration -> print screen the configuration
The cooking recipe:
1. Read eeprom with BDM (2kb size!)
2. Make virgin with ImmoDec 3.2
3. Disable immo on the virgin file with Immo tool v1.5
4. Load the eeprom file with BDM
5. With PP2000 go to ecu->confiuguration (notice all settings are virgin), do the correct configuration
6. Go to replacement parts->Injection->injectors , register the injector codes
ce n'est pas ce q u'il demande :'(
en une frac tion de seconde tout le dump est décodable
et possible d e immo off dans l a meme fraction de seconde avec vérification serveur du checksum de chaque bloc de donné s!!!
Winols BSL BDM IOT Officiel OLS505 disponible > 01/04/2021 en monoposte moins cher !
Kennfeld est déconnecté   Réponse avec citation
