Vieux 13/11/2017, 20h04
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 36
Tidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond repute
slt!
As tu bien suivi la procédure pour la resync en cas de problème? J'ai déjà eu ça et pour moi c'était reparti en suivant la procédure dans le manuel (grosse sueur d'ailleur!)
6.6.6 Synchronization in case of problem:
If, for some reason the key that you just made is not working (the CAS recognizes the key but the
engine does not start), then the DME and CAS may be desynchronized. Insert again the original
key and try to start the engine. If it does not start with the original key then follow these steps:
1. Click on DME unit, read its DTCs. Clear them, read them again. If you see some error that
cannot be deleted (most frequently this is “EWS manipulation error”), then you have to
disconnect the battery, wait about 5 min, connect it again. Click on DME / clear the errors.
This time there shouldn't be any DTCs left.
2. Click on CAS. Clear the DTCs.
3. Click on Synch DME-CAS special function. Wait for the synchronization to finish. If you
see error that synchronization failed – ignore it.
4. Start the engine with the original key.
---------- Post added at 22h04 ---------- Previous post was at 21h56 ----------
Envoyé par tico Voir le message
tu as bien suivi la procédure? parce que cas3 ça date un peu surtout si tu as du vrai matos...
me semble que c'est du cas3+ sur le x6...
Tidus97 est déconnecté   Réponse avec citation
The Following 7 Users Say Thank You to Tidus97 For This Useful Post:
barho67 (28/12/2017), Benoit974 (14/11/2017), everson29 (14/11/2017), jah83 (14/11/2017), pouettedu76 (13/11/2017), tdipower11 (03/12/2017), tony60 (13/11/2017)
