Vieux 14/11/2017, 04h54
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
@manudiag,
May be the issue is relevant to the French system, can you try changing Windows to US!!
By the way, both the Private and Public Networks should be ticked (my photos show only Public is ticked). You can change the settings from the Firewall settings, you don't need to re-install.
@sharediag,
DiagBox 7 and 8 do not change the Firmware revisions (from B to C etc..), but some releases upgrade Application Firmware 2.3.x. This function is usually disabled in maitresox releases, but I leave it on if it is as such in the original update.
I believe it would not harm you device as it is designed for the original devices.
However, you can disable it in the "C:\AWRoot\bin\launcher\ap.ini" (search the forun on how to do it) or insert the VCI USB cable after DiagBox starts.
Simple est déconnecté   Réponse avec citation
The Following User Says Thank You to Simple For This Useful Post:
manudiag (14/11/2017)
