Discussion: formation winols
Vieux 15/11/2017, 11h14
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 27
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Pour les programmes/plugins suivant des mises à jours sont disponibles :
- WinOLS main programm 3.94
- Fixed: Taskcard title progress bar no longer works
- Fixed: You cannot delete or save files inserted in the project commentary Files cannot be deleted or saved.
- Fixed: Import of map files did not consider elements
- Fixed: ImportWiz: File name with AND character is displayed incorrectly in dialog
- Fixed: Click on reseller in status bar caused wrong config page
- Fixed: ConnectBar: Slider was in the wrong position directly after the search
- Fixed: Connecting, n held down, only one window is refreshing live
- Fixed: MAP file import with elements did not yet work properly
- Fixed: Mass import: max. 1 version imported
- Fixed: Mass Import: Problems with search strings that are not only lowercase
- Fixed: After kp/csv import, KF were not entered in the scrollbar
- Fixed: pot. map close and do not accept => entry in KF list remained bold for some time
- Fixed: OpenPrj: Manufacturer: Passenger cars were not companies that also produce trucks
- Fixed: OpenPrj: Error during sorting, ab was not always sorted to a
- Fixed: Problems with auto-move corrupt files
- Fixed: Problems with unrar from file with alternative NTFS stream
- Fixed: Default column number from Cfg for new projects is ignored
- Fixed: Differences list was not updated when you click on X, change the project and then tap U
- Fixed: Many invalid KF-addresses at the KF transmitted have also caused many error messages
- New free DLL OLS550 just for the similarity search
- Search in OpenProject and map list: New keyword 'or' (or just a comma). Example:BMW or VW
- F12>Reseller: Advanced Security Server to store projects on a secured secondary server
- New: Edit-menu: Round values or limit to Min/Max
- New: Map list > EditMultipleMaps: Remove flagsm Round values or limit to Min/Max
- New: 3d: Ctrl+Alt+Mouse wheel: rotate
- New: CSV import: new/changed maps are selected afterwards
- New: Ctrl+Shift+ClickDrag => Scroll mode
- New: EditAsText: Search field is new standard field
- New: GoTo: Show comments as a list
- New: Hotkeys for transfer selected maps revised
- OLS550 Data Areas 1.00 (New, free plugin to support the similar projects search )
donc nouveau plugin free sur ols officiel ols 550
---------- Post added at 11h14 ---------- Previous post was at 11h13 ----------
59 nouveau textes pour cette version hop trad en cours
Winols BSL BDM IOT Officiel OLS505 disponible > 01/04/2021 en monoposte moins cher !
Kennfeld est déconnecté   Réponse avec citation
The Following User Says Thank You to Kennfeld For This Useful Post:
olivcab (15/11/2017)
