Discussion: defaut seat leon 2013
Vieux 22/11/2017, 21h27
fayssal2017
Avatar de fayssal2017
fayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond repute
Smile
Envoyé par hichemok Voir le message
slt tlm
je viens de acheter une leon et j trouver c erreur c grave ????
Wednesday,04,October,2017,2050:05533
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: VSSZZZ1PZDR...... License Plate: 05/10/2017
Mileage: 106160km-65964mi Repair Order:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: VSSZZZ1PZDR...... Mileage: 106160km-65964miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CLCB) Labels: None
Part No SW: 03L 906 018 GM HW: 03L 906 018 FJ
Component: R4 2,0L EDC H25 1008
Revision: 42H25--- Serial number:
Coding: 00190012042400080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM20TDI01103L906018GM 003004
ROD: EV_ECM20TDI01103L906018GM.rod
VCID: 7BF5A630F2F0FDF93BD-802E
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 113B4012092500FB881002E690210042350800
Shop #: WSC 04941 000 00000
VCID: 7DF1A828E4E4F3C9059-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 106169 km
Time Indication: 0
Date: 2017.10.04
Time: 2019
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 397
Count: 49408
Count: 65024
Count: 254
Count: 0
Address 08: Auto HVAC (J255) Labels: None
Part No SW: ----------- HW: -----------
Component: Climatronic 0909
Revision: --------
Coding: 0000004002
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 6FED8260B6889159875-803A
2 Faults Found:
9472021 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 106169 km
Date: 2017.10.04
Time: 2056
9479185 - Signal Line for Air Quality Sensor
B10A4 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 0
Mileage: 106169 km
Date: 2017.10.04
Time: 2056
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 R HW: 5K0 937 087 R
Component: BCM PQ35 H 021 0068
Revision: BE021001
Coding: 46180A3E80250CC042080080950089C442550008627D816000 8040000040
Shop #: WSC 00011 888 77253
VCID: 44871DCCC78E42010A7-8011
Subsystem 1 - Part No: 1P0 955 119 D
Component: Wischer 30101 26 0611
Coding: 00DB90
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 106169 km
Time Indication: 0
Date: 2017.10.04
Time: 2031
Freeze Frame:
Term 15 On
Voltage: 13.75 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__A0A VW10 HI 2118
Revision: 24017000 Serial number: 003L7PNS0T18
Coding: 0012353
VCID: 7CF7A52C3FFEFAC1327-8029
Subsystem 1 - Serial number: 6332MTS615842952
Subsystem 2 - Serial number: 6342MTS621242952
Subsystem 3 - Serial number: 6351HTS616O5FBKR
Subsystem 4 - Serial number: 6361HTS686DHHBKJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121103200295
Coding: 1082140002
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F9BC38F8CCCFE9291-802C
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 850 N HW: 1P0 920 850 N
Component: KOMBI H03 0705
Coding: 110E01
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 377D7A008E5819999F5-8062
Coding: 110E01
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 211012F2000865
Coding: 350202
VCID: 74E78D0CD7AEB2817A7-8021
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0705
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADB93748D6A7471D0B-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663690733
Coding: 010100
VCID: 2A5B537445EAB47110B-807F
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0507
Revision: 12110009 Serial number: 0005681203
Coding: 0010B0
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DD19868BC846349B59-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 E HW: 3C0 959 795 E
Component: J388__TSG-HL 008 1501
Serial number: 00000007307959
Coding: 000090
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 142 3305
Revision: 00H22000
VCID: 377D7A00465819999F5-8062
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0507
Revision: 14110009 Serial number: 0005737605
Coding: 0010B0
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED39F64B18298518C3-803B
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 E HW: 3C0 959 794 E
Component: J389__TSG-HR 008 1501
Serial number: 00000007314963
Coding: 000090
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 2556933
VCID: 34674D0C572EF281BA7-8061
Subsystem 1 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul l 0004
Coding: 00000039
Subsystem 2 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul r 0004
Coding: 00000039
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5P0 035 186 B HW: 5P0 035 186 B
Component: Media2.0 004 0082
Revision: 01000001 Serial number: SEZ1Z3M5089824
Coding: 01060400040000
VCID: 2E535F647902D851CC3-807B
End-------------------------(Elapsed Time: 02:59)--------------------------
Salem khoya hichemok,
Je confirme que la réf. de la climatronic de ce véhicule est adaptable, mais il reste le codage en premier (je vais essayé de t'envoyé un codage dans quelques jour), si ce dernier ne réussi pas à éliminé l'anomalie alors vous avez une climatronic à changer (noté que dans votre rapport VCDS il n'y a que le calculateur climatronic qui ne lit pas la référence, j'ais mis en rouge pour faciliter la compréhension).
Il y a une nette différence entre ancienneté et expérience
fayssal2017 est déconnecté   Réponse avec citation
The Following User Says Thank You to fayssal2017 For This Useful Post:
zenata (22/11/2017)
