Vieux 20/12/2017, 18h21
dadal
Avatar de dadal
dadal will become famous soon enoughdadal will become famous soon enough
Envoyé par MrRorry Voir le message
Hi,
yes, you need register, you can follow these steps of the nice jeremy72's tutorial
Check the prerequistes, you can use DDT2000_tester.exe int the exe directory
Yes, ddt2000 will work without any issue on Windows 7 x86 or x64
But of course you need a derelek probe to use this software.
Regards.
Thank you MrRorry,
I dont have Derelek, I thought it would work with kkl cable, I can use only old versions of ddt2000( like as v2.3..) without problem.
I wanted to use an english version and donwloade v2.6 and v2.9 but then I get then each time this error :
xmlnews.parseError=tme system cannot locate the resourse specified
I will try an old version ( cracked) with your new Database..
do some know what is the ****** price of Derelek cable ? renolink does works also with ddt2000?
dadal est déconnecté   Réponse avec citation
