Discussion: vcds codage polo
Vieux 28/12/2017, 21h12
abdel93
Avatar de abdel93
Pouvoir de réputation: 31
abdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond reputeabdel93 has a reputation beyond repute
Envoyé par abdou22 Voir le message
bon soire les amis.
j'ai besoin de codage polo 6r pour mode us que j'ai pas trouver sur le site ankk.
et codage activation alarme pour polo 6r et 6c.
merci d'avance
slm
Permet d'activer les clignotants US.
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (8)-Leuchte 16BLK SLC11-Light_Function_C_16
< Daytime running lights >
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (8)-Leuchte17 BLK SR A72-Light_Function_C_17
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (10)-Leuchte 16BLK SLC11-Dimming_CD_16
Mettre une valeur entre 0 et 100 (eclairage du feux entre 0 et 100%)
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (10)-Leuchte17 BLK SR A72-Dimming_CD_17
Si vous souhaitez que les clignotants s'eteignent completement lorqu'ils sont actives, il faut rajouter les codages suivants.
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (12)-Leuchte16BLK SLC11-Light_Function_E_16
< Blinken links Dunkelphase >
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (15)-Leuchte16BLK SLC11-Dimming_Direction_EF_16
< minimize >
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Adaptation - 10] -> < (12)-Leuchte17 BLK SR A72-Light_Function_E_17
< Blinken rechts Dunkelphase >
Leuchte 0 BLK VL B35
Light_Function_C_0 : Standlicht vorn
Dimming_CD_0 : Mettre une valeur entre 0 et 100 (eclairage du feux entre 0 et 100%)
Light_Function_E_0 : Blinken links Dunkelphase
Dimming_Direction_EF_0 : minimize
pour activer le mode US comme un feu de jour (il s'allume dans tous les modes 0 auto ...) :
Light_Function_D_0 : feu de jour
Leuchte1BLK VRB23
Light_Function_C_1 : Standlicht vorn
Dimming_CD_1 : Mettre une valeur entre 0 et 100 (eclairage du feux entre 0 et 100%)
Light_Function_E_1 : Blinken rechts Dunkelphase
Dimming_Direction_EF_1 : minimize
Light_Function_D_1 : feu de jour
permet d'activer le Klaxon comme alarme si ouverture des portes verrouillees de l'interieur
[09 - Centrale Electrique] -> [Security Access - 16] 31347 -> [Codage- 07] -> [Assistant Codage Long] ->
Octet 12: on coche
bit 0 Anti Theft-System installed/active (PR-7AL)
bit 7 ou bit 6 : Start Anti-Theft Alarm Delay with mechanical (Door Lock) Opening (Thatcham)
On ferme et on valide.
Anti-theft device-Akustischer Alarm Signalhorn
Actif
Anti-theft device-DWA Alarmverzoegerung
mais delay_driver_door_contact_that​cham
On valide le tous et on sort, On fait le test , il faut attendre que le coupe circuit sois mis en route 30s et puis on ouvre.
un petit thank ca fait pas de mal
abdel93 est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to abdel93 For This Useful Post:
abdou22 (18/08/2018), formator2 (20/02/2018), jah83 (28/12/2017), Marouane (30/05/2019)
