voici le tuto du cd d'install
Install
Windows 98/SE is not supported
Windows XP must be updated with SP1 or later
Windows Vista/7 64-bit is supported by upausb.sys (64-bit) driver. Please read details at
...\ELRASOFT\UPA-USB Suite\USB Driver\Win_Xp_Vista_7_x64
1. Uninstall older version, then run setup.exe to install the new one
2. Copy uuprog.lic file to uuprog software folder - this file is attached to the software registration email
if you have no uuprog.lic - contact
[email protected]
3. install the usb driver
If the uuprog software will be installed for first time to this computer you have to install the usb driver
See UsbDriverInstallationGuide.pdf located in device programmer help folder for instructions.
usb drivers are included in sw uuprog_xxxx.zip
if you'd like to use both old(1.1) and new (v1.2)uuprog software
Do not install the new usb driver upausb.sys because uuprog v1.1 can not work with this driver
uuprog v1.1 works with the old ezusb.sys driver
uuprog v1.2 works with the old ezusb.sys driver and with newer upausb.sys
You can install ezusb.sys driver in windows device manager
win 64-bit
upausb.sys
Supported OS: Windows 64-bit XP, Vista, 7
UPA-USB Device Programmer Software v1.2 or later
UPA-USB Logic Analyzer Software v1.2 or later
UPA-USB CAN Bus Analyzer v 1.2 or later
Warning: upausb.sys is not a signed driver, so you have to use a "special method to boot in Windows 64-bit.
There are still a few working ways to load unsigned drivers though.
One of these methods is to continuously press F8 when Windows is booted up until you get the Advanced Boot Options, then select ìDisable Driver Signature Enforcementì.
