Discussion: C5 ne demarre pas.
Vieux 17/01/2012, 08h53
fedge
Avatar de fedge
Pouvoir de réputation: 30
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
De mémoire , volant moteur pigé , le trou de la poulie d' aac était a un ou deux cm du trou du carter . En angle sur la poulie , je dirais a peu prés 20 degrés , ce qui fait 10 degrés sur le vilo.
fedge est déconnecté   Réponse avec citation
The Following User Says Thank You to fedge For This Useful Post:
popeye05 (17/01/2012)
