Vieux 06/02/2018, 22h15
neflerine
Avatar de neflerine
neflerine is just really niceneflerine is just really niceneflerine is just really niceneflerine is just really niceneflerine is just really nice
Par défaut ODB 2007 avec clé d'activation
Logiciel avec clé d'activation a mettre.
la clé pour activer le logiciel se trouve dans l'archive zip
Merci de me demander le mot de passe de l'archive par MP
Lien MEGA ici :
https://mega.nz/#!hc4yRSza!4A41slzI9...Syn0GwaT-GWQqg
ODB 2007
Description en Anglais du logiciel :
OBD 2007 is a family of OBD II software applications designed to assist automotive professionals and enthusiasts alike in diagnosing and analysing problems with modern vehicle engines. Presently there are two versions of OBD 2007, one for PCs, laptops and Windows Vista UMPCs and another for Pocket PCs.
Purchase this software alongwith an OBDPro interface for an additional discount. See the OBDPro interfaces page for details.
Please Note: Once you purchase this software you will be provided with a download link to download the software.
We cannot offer refunds for software purchases, if you would like to try out this software before purchasing visit www.GLMSoftware.com and download the available 7 day free trial.
Feature summary:
OBD 2007 supports all services $01 through $09 as specified by SAE J1979 and ISO 15031-5.
01 � Current Power train Diagnostic Data.
02 � Power train Freeze Frame Data.
03 � Emission-Related Diagnostic Trouble Codes.
04 � Clear/Reset Emission-Related Diagnostic Information.
05 � Oxygen Sensor Monitoring Test Results.
06 � On-Board monitoring Test Results for specific monitored systems.
07 � Emission-related Diagnostic Trouble Codes detected during last drive cycle.
08 � Control of On-Board System components.
09 � Vehicle Information.
Supports the following:
Continuous real time digital display of up to 90 Pids of power train data.
Continuous real time graphic display of up to 90 Pids of power train data.
Automatically supports all vehicle protocols including J1850 PWM, J1850 VPW, ISO 9141, ISO 14230, and ISO 15765 (11 and 29 bit CAN).
Display of Vehicle readiness - Continuous and Non Continuous monitoring and monitor status of MIL lamp and detected Diagnostics Trouble Codes.
Display of Freeze frame pid data as stored in the vehicle�s ECU.
Displays both stored and pending Diagnostic Trouble Codes.
Clearing/Resetting engine MIL light.
Display of Oxygen sensor data.
Display of On Board monitoring of non continuous tests.
Display of vehicle information including VIN number.
Display of virtual dashboard for display of real time data, including an instantaneous fuel consumption gauge.
Logging of both diagnostic data and real time data, suitable for importing in Microsoft�s Excel.
Displays data in either Metric or Imperial, automatically adjusting based on the Window�s Region setting.
Sensor information can be individually selected or deselected.
Display of vehicle�s OBD compliance, protocol and scan tool interface and version.
Sensors display current, minimum, maximum and average values.
Connection support by either Bluetooth serial or cable serial. Com and baud rate saved for future sessions after initial selection.
Summary display of vehicle�s supported services.
Connection tab displays real time hexadecimal data for those conversant with SAE J1979 or ISO 15031-5.
OBD Terminal mode for those who wish to directly send commands to the scan tool or the vehicle�s ECUs.
Incremental adjustment of Elm 327 timeout value to maximize sensor response speed.
Fully incorporated help manual of our easy to read OBD 2007 Program Guide.
Version check with our server for program version updates and integrated download of new versions for registered users.
Fully featured demo of both products, limited to 7 days by an activation license with our server.
Additional modules:
Dashboard and Fuel Analysis gauges
Graphic data module. The ability to graph any 4 pids in real time
Mapping module
Playback module
Acceleration test module
Automatic discovery of correct com port and factory set baud rate of scan tool
Support for high speed baud rates up to 2.0Mbps
neflerine est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to neflerine For This Useful Post:
adiago (07/02/2018), klif26 (07/02/2018), vortex (07/02/2018)
