Vieux 15/02/2018, 16h56
fayssal2017
Avatar de fayssal2017
fayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond reputefayssal2017 has a reputation beyond repute
Envoyé par alexvin Voir le message
j ai shunté que le ventilo a grande vitesse j ai en enlever le relais et j ai shunté le 30 et 87
Alors deux proposition:
-problème du circuit de commande du relais
-problème de relais
---------- Post added at 17h55 ---------- Previous post was at 17h50 ----------
Contrôle tous les fusibles,
Remplace le relais avec un autre juste pour voir si la 1ère vitesse du ventilo fonctionne
---------- Post added at 17h56 ---------- Previous post was at 17h55 ----------
Il y a une nette différence entre ancienneté et expérience
fayssal2017 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to fayssal2017 For This Useful Post:
alexvin (16/02/2018), zenata (15/02/2018)
