Vieux 23/01/2012, 21h57
crenshaw
Avatar de crenshaw
crenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nicecrenshaw is just really nice
Envoyé par nany Voir le message
Hi guys, i have a trick to make all sirius 32 start. After programming the 29F200, i lift the pin number 43 from 29f200 (Write enable#) and i connect to 5V (pin number 23 from 29F200). The engine starts and when the ecu wants to modified the 29F200, it won´t because we disable the writing. Make sure that you program a good dump from the correct engine. I have 4 categories.
- 1.6 8V with A/C
- 1.6 8V without A/C
- 1.6 16V with A/C
- 1.6 16V without A/C
These are all engine types with sirius 32 Pièce jointe 2937
These are the dump for the 4 categories, REMEMBER: CUT WIRE 58.
donc sa se n est pas valable ???qui a teste cet solution avec succes ??
donc immo off plus fil line immo 58 coupé sa fai l affaire sans avoir besoin d emulateur ??
tout est flou on devrai a chaque fois donne les resultat d essai si sa fonctionne ou pas
Dernière modification par crenshaw ; 23/01/2012 à 22h03.
crenshaw est déconnecté   Réponse avec citation
