Vieux 22/03/2018, 15h05
CHATONDU38
Avatar de CHATONDU38
CHATONDU38 is a glorious beacon of lightCHATONDU38 is a glorious beacon of lightCHATONDU38 is a glorious beacon of lightCHATONDU38 is a glorious beacon of lightCHATONDU38 is a glorious beacon of light
C est pour ca
Seat Occupied Recognition Control Module (J706): Reset
If a repair on the Seat Occupied Recognition has been performed, including the above basic settings procedure, a reset has to be performed too.
Prerequisites:
The Seat Occupied Recognition Control Module (J706) Basic Settings was successful.
The vehicle is between 5° and 35°C (40° ~ 95°F).
Battery voltage no less than 12.4 V.
Passenger seat is empty and in normal position.
Seatbelt must NOT be plugged in.
No Component Protection, Control Module Faulty, Crash Data Stored, Control Module Not Coded or Igniter faults in the system.
[Security Access - 16]
Enter the Basic Settings Enabling (Seat Occupied Recognition Control Module) code shown in the pop-up balloon to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Select Resetting seat occupied recognition.
When applicable type the single digit 0 into the (reserved) box. If this is not present skip this step.
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
The reset has been performed.
[Done, Go Back]
[Fault Codes - 02] Faults should NOT be stored
[Close Controller, Go Back - 06]
---------- Post added at 15h05 ---------- Previous post was at 15h00 ----------
plutot ceci
Seat Belt Tensioner Control Module Reset
Prerequisites:
New Seat Belt Tensioner installed
Fault such as B1304 - Left front seat belt tensioner control module: Not configured and B1305 - Right front seat belt tensioner control module: Not configured are normal prior to the matching procedure.
Warning message on dash "Audi Pre Sense System Fault!" may be displayed when ignition is turned on.
[Select]
[15 - Airbags]
Enter the Basic Settings Enabling (Belt Tensioners) code shown in the pop-up balloon to enable the basic setting.
[Do it!]
Select Left belt tensioner serial number -or- Right belt tensioner serial number depending on the new component(s).
If both belts were replaced repeat for the other side at this point
[Done, Go Back]
CHATONDU38 est déconnecté   Réponse avec citation
