Vieux 24/01/2012, 23h52
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 182
cedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond repute
Envoyé par vcloclo1 Voir le message
A quoi sert se soft ?
Code:
ADVANCED IMMO REPAIR SYSTEM VERSION 2
What is otocheck immo tool ?
 Otocheck is an advanced Immobilizer repair tool used to repair immobilizer
problems in vehicles with faulty ECU's or immo boxes or in situation where
all keys have been lost. It can also be used for track cars where a donor
engine has been used or an ECU swap out. This is an advance tool with
a comprehensive coverage a must for all lock smiths and ECU repair
stations worldwide.
Using the software
 In Order to repair an immobilizer problem we first need to read the chip that
stores the immobilizer data. This is normally in the form of an 8 pin Eprom
 found in the ECU or immobilizer box located behind the dash.
If you are unsure of the location or chip type you can select the make/model
before starting in order to identify the chip/location in question. Once
identified you will need to read the chip with your own programmer. For
 Eproms we recommend SeeProg by Elnec and for a wider chip coverage UPA
USB by elrasoft which will cover many MCU processors. After reading the
chip save a copy to your machine (also make a backup) to load into the software.
cedrsan est déconnecté   Réponse avec citation
