					Envoyé par  CHIKODIAG
				HI
here a working virgin file for the new uch
if you do immo off on ecu and feat the new uch the car wille start but there is no working remot and you wille need the pin from the new uch to programe a new key and ...................SO YOU KNOW
you need one working key to programe the uch
good luck
 Thank you dear friend,
I will try first with virgin file, I wil try also to get pincode to program UCH.
if not possible then I will make ecu immo off, remote control is not so important, if other functions does works, it is fine
Thanks again for your effort
