Vieux 25/01/2012, 23h37
cedrsan
Avatar de cedrsan
Pouvoir de réputation: 182
cedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond reputecedrsan has a reputation beyond repute
Envoyé par vcloclo1 Voir le message
Ta pas la traduction, car moi et l'anglais c'est très limiter ?
Faut faire une petite formation d'anglais ou des court de rattrapage
Si je te donne une pomme je vais pas te la macher pour que tu l'a mange
Tu peux utiliser Google traducton pour ca ! (même si le francais est traduit a la va vite, c'est parfaitement compréhensible)
Code:
http://translate.google.fr/?hl=fr&tab=wT#en|fr|ADVANCED%20IMMO%20REPAIR%20SYSTEM%20VERSION%202%0A%20%0AWhat%20is%20otocheck%20immo%20tool%20%3F%0A%20Otocheck%20is%20an%20advanced%20Immobilizer%20repair%20tool%20used%20to%20repair%20immobilizer%20%0Aproblems%20in%20vehicles%20with%20faulty%20ECU's%20or%20immo%20boxes%20or%20in%20situation%20where%20%0Aall%20keys%20have%20been%20lost.%20It%20can%20also%20be%20used%20for%20track%20cars%20where%20a%20donor%20%0Aengine%20has%20been%20used%20or%20an%20ECU%20swap%20out.%20This%20is%20an%20advance%20tool%20with%20%0Aa%20comprehensive%20coverage%20a%20must%20for%20all%20lock%20smiths%20and%20ECU%20repair%20%0Astations%20worldwide.%0A%20%0AUsing%20the%20software%0A%20In%20Order%20to%20repair%20an%20immobilizer%20problem%20we%20first%20need%20to%20read%20the%20chip%20that%20%0Astores%20the%20immobilizer%20data.%20This%20is%20normally%20in%20the%20form%20of%20an%208%20pin%20Eprom%0A%20found%20in%20the%20ECU%20or%20immobilizer%20box%20located%20behind%20the%20dash.%0AIf%20you%20are%20unsure%20of%20the%20location%20or%20chip%20type%20you%20can%20select%20the%20make%2Fmodel%20%0Abefore%20starting%20in%20order%20to%20identify%20the%20chip%2Flocation%20in%20question.%20Once%20%0Aidentified%20you%20will%20need%20to%20read%20the%20chip%20with%20your%20own%20programmer.%20For%0A%20Eproms%20we%20recommend%20SeeProg%20by%20Elnec%20and%20for%20a%20wider%20chip%20coverage%20UPA%20%0AUSB%20by%20elrasoft%20which%20will%20cover%20many%20MCU%20processors.%20After%20reading%20the%20%0Achip%20save%20a%20copy%20to%20your%20machine%20(also%20make%20a%20backup)%20to%20load%20into%20the%20software.
cedrsan est déconnecté   Réponse avec citation
The Following 6 Users Say Thank You to cedrsan For This Useful Post:
Amine-TE (26/01/2012), autodiagauto (12/03/2017), karlamine (06/07/2013), mecanodiag93 (25/11/2012), Scanworld2020 (17/03/2014), youcef_trik (15/10/2012)
