Vieux 04/05/2018, 20h17
oliv xii
Avatar de oliv xii
Pouvoir de réputation: 8
oliv xii is on a distinguished road
Thumbs up
bon je revient vers vous, j'attendant de recevoir mes cables, avec vag tacho j'ai pu recuperer le pin dash ( le meme que alinjadii m'avais donner), ensuite avec super vag k+can 1.4 j'ai lu mon eeprom ecu et recuperé le pin, ensuite plus qu'a suivre la procedure :
Engine Control Unit (ECU) Swapping (USED ECU)
Prerequisites:
The REPLACEMENT (USED) ECU is installed in the car.
Battery voltage at least 12.5 V.
All relevant coding and adaptation values have been transferred from the ORIGINAL (OLD) ECU to the REPLACEMENT (USED) ECU.
Make sure to have BOTH PIN's, from the ORIGINAL (OLD) and the REPLACEMENT (USED) ECU.
Make sure to have the Radio Code (for factory radios only).
[Select]
[01 - Engine]
[Login - 11]
For the following procedure, use the PIN of the REPLACEMENT (USED) ECU.
4-digit PIN
The PIN needs to be entered as 5-digit number in the New Value box. For example, if your PIN is 1234, enter 01234.
[Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
For the following procedure, use the PIN of the ORIGINAL (OLD) ECU.
4-digit PIN
The PIN needs to be entered as 5-digit number. For example, if your PIN is 1234, enter 01234.
[Test]
The values may change to "32000", this is normal
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]s
et nikel tout les paramettres se sont adaptés et ca démarre, merci a tous pour vos aides
oliv xii est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to oliv xii For This Useful Post:
alinjadii (04/05/2018), diagnosis29 (04/05/2018), jphp (04/05/2018), stephane (06/05/2018)
