Vieux 16/05/2018, 21h58
vwseb
Avatar de vwseb
Normalement avec VCDS:
[Select]
[15 - Airbags]
[Security Access - 16]
Enter the Basic Settings Enabling (Seat Occupied Recognition Control Module) code shown in the pop-up balloon to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Select Seat occupied recognition serial number.
When applicable type the single digit 0 into the (reserved) box. If this is not present skip this step.
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
The Seat occupied recognition serial number reset has been performed. Proceed directly to the Seat Occupied Recognition Control Module (J706): Reset procedure!
If a repair on the Seat Occupied Recognition has been performed, including the above basic settings procedure, a reset has to be performed too.
Prerequisites:
The Seat Occupied Recognition Control Module (J706) Basic Settings was successful.
The vehicle is between 5° and 35°C (40° ~ 95°F).
Battery voltage no less than 12.4 V.
Passenger seat is empty and in normal position.
Seatbelt must NOT be plugged in.
No Component Protection, Control Module Faulty, Crash Data Stored, Control Module Not Coded or Igniter faults in the system.
[Do it!]
Select Resetting seat occupied recognition.
The reset has been performed.
[Done, Go Back]
[Fault Codes - 02] Faults should NOT be stored
[Close Controller, Go Back - 06]
Note
If you get a "Request Sequence Error" when performing the above procedures using VCDS Release 17.8 please update to the current Release: http://www.ross-tech.com/vcds/download/current.php
Seat Belt Tensioner Control Module Reset
Prerequisites:
New Seat Belt Tensioner installed
Fault such as B1304 - Left front seat belt tensioner control module: Not configured and B1305 - Right front seat belt tensioner control module: Not configured are normal prior to the matching procedure.
Warning message on dash "Audi Pre Sense System Fault!" may be displayed when ignition is turned on.
[Select]
[15 - Airbags]
Enter the Basic Settings Enabling (Belt Tensioners) code shown in the pop-up balloon to enable the basic setting.
[Do it!]
Select Left belt tensioner serial number -or- Right belt tensioner serial number depending on the new component(s).
If both belts were replaced repeat for the other side at this point
[Done, Go Back]
vwseb est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to vwseb For This Useful Post:
alinjadii (16/05/2018), Memed bubba (17/05/2018), zenata (16/05/2018)
