Vieux 20/05/2018, 17h20
rotax
Avatar de rotax
Pouvoir de réputation: 35
rotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond reputerotax has a reputation beyond repute
es ce que tu as bouger/modifier le passage et point de fixation sur la boite du cables de masse ?
si oui essaye de le repositionner correctement et/ou éloigne le au maximum du capteur de régime d'arbre primaire.
tu as bien le stop and start sur ta voiture ?
rotax est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to rotax For This Useful Post:
jphp (20/05/2018), Nabs78 (20/05/2018), zenata (25/05/2018)
