Have a look at "Computer Management"-->"Event Viewer" and check your System and Application Events. Be sure to look at the time the installation took place and at the time you try to start it.
You may see why (error codes) the database failed or didn't get installed or why the app couldn't connect to the database.
If there is no error discription, google the error code.
You might also check if the database service(s) are running.
Dernière modification par PanBlue ; 01/02/2012 à 16h53.
