Vieux 30/06/2018, 23h46
oliv xii
Avatar de oliv xii
Pouvoir de réputation: 9
oliv xii is on a distinguished road
Par défaut Wastegate faible sur k04 hybride
salut a tous,
en regrdant mes logs je m'apercoit que ma Wastegate faibli et lache a 1.5bars du coup ma n75 essaie de compenser mais ca ne me plais pas, auriez vous un wg renforcé a me donner en lien achat pour que je la change, je change aussi ma pompe car pas sez de debit pour les inject 550cc, merci
Saturday,30,June,2018,1425:04550-VCID:367D24DFD8478D82F57C80D-515F,VCDS Version: Release 15.7.0,Data version: 20150820
8N0 906 018 H,,1.8L R4/5VT G 0004,
,Group A:,'001,,,,Group B:,'020,,,,Group C:,'031
,,Engine Speed,Coolant,Lambda Control,Basic Setting,,Timing Retardation,Timing Retardation,Timing Retardation,Timing Retardation,,Lambda Control,Lambda Control,Bin. Bits,Bin. Bits
,TIME,(G28),Temperature (G62),Bank 1,Requirements,TIME,Cylinder 1,Cylinder 2,Cylinder 3,Cylinder 4,TIME,Bank 1 (******),Bank 1 (specified),,
Marker,STAMP, /min,°C, %,,STAMP,°KW,°KW,°KW,°KW,STAMP,,,,
,0.61,1960,94.0,0.0,01100011,0.08,0.0,0.0,0.0,0.0, 0.30,1.047,0.961, ,
,1.51,2200,94.0,0.0,01100001,0.91,0.0,0.0,0.0,0.0, 1.21,0.914,0.945, ,
,2.42,2560,94.0,0.0,01100001,1.81,0.0,0.0,0.0,0.0, 2.11,0.828,0.938, ,
,3.33,3000,94.0,0.0,01100001,2.71,0.0,3.0,0.0,0.0, 3.03,0.821,0.938, ,
,4.22,3440,95.0,0.0,01100001,3.63,0.0,3.0,0.0,0.0, 3.92,0.992,0.922, ,
,5.14,3920,95.0,0.0,01100001,4.54,0.0,2.3,0.0,0.0, 4.84,1.109,0.899, ,
,6.04,4400,95.0,0.0,01100001,5.44,0.0,2.3,0.0,0.0, 5.74,1.148,0.922, ,
,6.95,4840,95.0,0.0,01100001,6.34,0.0,1.5,0.0,0.0, 6.65,1.094,0.867, ,
,7.85,5240,95.0,0.0,01100001,7.25,6.0,6.8,9.0,6.0, 7.55,1.055,0.821, ,
,8.76,5640,95.0,0.0,01100001,8.15,9.0,9.8,12.0,12. 0,8.46,1.070,0.813, ,
,9.66,5960,96.0,0.0,01100001,9.06,9.0,12.8,12.0,12 .0,9.36,0.945,0.688, ,
,10.57,6280,96.0,0.0,01100001,9.97,11.3,12.8,12.8, 11.3,10.27,0.867,0.649, ,
,11.47,6560,96.0,0.0,01100001,10.87,11.3,12.0,12.8 ,11.3,11.17,0.860,0.649, ,
,12.38,6840,96.0,0.0,01100001,11.79,10.5,12.0,12.0 ,12.8,12.08,0.852,0.649, ,
Saturday,30,June,2018,1447:04550-VCID:367D24DFD8478D82F57C80D-515F,VCDS Version: Release 15.7.0,Data version: 20150820
,Group A:,'001,,,,Group B:,'115,,,,Group C:,'118
,,Engine Speed,Coolant,Lambda Control,Basic Setting,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,Engine Speed,Intake Air,Boost Pressure,Boost Pressure
,TIME,(G28),Temperature (G62),Bank 1,Requirements,TIME,(G28),,(specified),(******),TI ME,(G28),Temperature (G42),Control (N75),(******)
Marker,STAMP, /min,°C, %,,STAMP, /min, %, mbar, mbar,STAMP, /min,°C, %, mbar
,0.59,2400,90.0,0.0,01100001,0.00,2240,69.9,1030.0 ,1050.0,0.29,2320,49.0,60.0,1090.0
,1.50,2720,90.0,0.0,01100001,0.90,2480,115.0,2460. 0,1250.0,1.20,2600,46.0,94.5,1360.0
,2.41,3120,90.0,0.0,01100001,1.80,2840,151.1,2520. 0,1660.0,2.10,2960,44.0,94.5,1870.0
,3.31,3600,90.0,0.0,01100001,2.71,3280,191.7,2510. 0,2320.0,3.02,3440,42.0,93.7,2410.0
,4.22,4120,90.0,0.0,01100001,3.62,3800,191.7,2510. 0,2430.0,3.92,3960,42.0,92.9,2450.0
,5.13,4640,90.0,0.0,01100001,4.52,4320,191.7,2500. 0,2460.0,4.83,4480,44.0,94.5,2420.0
,6.03,5120,90.0,0.0,01100001,5.43,4800,191.7,2500. 0,2390.0,5.73,4960,45.0,94.5,2360.0
,6.94,5560,90.0,0.0,01100001,6.34,5280,191.7,2480. 0,2340.0,6.64,5400,49.0,94.5,2270.0
,7.84,5880,90.0,0.0,01100001,7.24,5680,178.9,2470. 0,2130.0,7.54,5760,51.0,94.5,2080.0
,8.75,6240,90.0,0.0,01100001,8.15,6000,161.7,2470. 0,2070.0,8.45,6120,54.0,94.5,2010.0
,9.65,6560,91.0,0.0,01100001,9.05,6320,155.6,2440. 0,1930.0,9.35,6440,55.0,94.5,1900.0
Dernière modification par oliv xii ; 01/07/2018 à 15h34.
oliv xii est déconnecté   Réponse avec citation
