Vieux 12/08/2018, 10h55
hichemok
Banned
Avatar de hichemok
hichemok is on a distinguished road
Establishing diagnostic session with the selected unit...
Diagnostic channel is open - High Speed CAN bus.
--- electronic control unit identification ---
Functional Plan No: 9654596080
Manufacturer: Magneti Marelli
Functional Product No: 9654596080
Software Index: 255.255
Diagnostic Index: M
System: 02
Software edition: 06.02
Software signature: 86.59
Software reference: 9663380880
Manufactoring Date2: 1/2/2007
Programming Date: 1/2/2007
Reprogramming counter: 1
Locking of the ECU ECU not locked
Immobiliser status Matched ECU
Synchronisation status No problem detected
--- read diagnostic trouble codes ---
Permanent fault. P0170: Richness regulation
Characterisation of the fault: Coherence
Permanent fault. P0132: Upstream oxygen sensor signal
Characterisation of the fault: Short circuit to positiveOpen circuit
Intermittent. P0012: Variable timing electrovalve
Characterisation of the fault: Locked at the lower stop
Permanent fault. P0075: Variable timing electrovalve
Characterisation of the fault: Problem
Permanent fault. P0485: Status of the fan assembly
Characterisation of the fault: Short circuit to negativeShort circuit to positiveOpen circuit
Intermittent. P0010: Variable timing electrovalve
Total: 6 DTCs found
hichemok est déconnecté   Réponse avec citation
