Vieux 14/08/2018, 17h13
enteran
Avatar de enteran
enteran has a spectacular aura aboutenteran has a spectacular aura about
Par défaut Online activation of software on EASYDIAG 3.0 without buying brands
This scanner has recently appeared on sale and it has several improvements, compared to the old ones. It works much faster. Inside its main circuits with protective diodes. Works with voltage up to 18 volts.
The best and most effective way to activate car brands is online activation!
The program interface is in English. More than 200 car brands in different languages.
Only ONLINE activation reveals all the functionality of 431 PRO on EASYDIAG 3.0, including special functions.
After carrying out the diagnostics, the report can be printed or sent to e-mail.
The software update takes place online, the program checks for updates of brands, downloads and installs them.
The full program can reach about 6 Gb in the memory of the device.
Here you can buy the scanner itself: http://shopeasy.by/cashback/view/pcr...adf53c00cNDGTF
Instructions, read all to the end and carefully. If something is not clear, read it again. I tried to write answers to all the questions that arise.
To register devices 97699,97709 (EasyDiag 3.0, Golo Master 3.0) it is necessary to replace the original BOOT on BOOT from XDIAG.
---- 1. This eliminates all problems with unstable device operation.
---- 2. This allows you to register the device without buying a brand. (By serial number)
To change the name of the programmer ST-LINK, aliexpress costs about 2$ http://shopeasy.by/cashback/view/pcr...6c873c00NwzGbS
Instruction in English
The file can be obtained from the link:
https://yadi.sk/i/iK6U1Lxe3Z6TJa
https://yadi.sk/d/7L89kcU23a9X3R
https://yadi.sk/d/Gwe7mKE43Yzdcg
https://yadi.sk/d/uOMQWwEw3aCQPq
https://yadi.sk/i/oILXolO93a7qZM
Evaluate your abilities correctly.
FROM YOU NEED ONLY SERIAL NUMBER ADAPTER.
I will give the firmware and login and password for downloading stamps from the program.
Choose the option that suits you.
Currently there are 2 ways to activate the devices:
1. Online activation and access to the server with stamps for a year, with the ability to download updates from MY program, as in the original version (after a year, all the stamps remain with you and continue to work, simply you will not be able to update later). Everything works as in the PRO version ... adaptation, training and so on. Works with one, your adapter, others can not be used with your program. You can install and use on 3 devices!
2. Online activation and access to the server with stamps for three days, you can download all brands within three days from MY program, without the possibility of up****** them within a year. Downloaded and used, those versions of brands that were on the download day from the update server. Work will be without restrictions. All as in the PRO version ... adaptation, training and so on. Works with one, your adapter, others can not be used with your program. You can install and use on 3 devices!
After that, I immediately accept all the data and activate it. And while you are putting the program for work and uploading stamps
To enter I will give my login and password.
I can make 1 mark on the test for free.
On Audi stamps and Volkswagen at Launch in expensive scanners there is a function of guided diagnostics, it turns out this scanner can use it as well.
Audi and Volkswagenare downloaded by default without this function.
In order to download it to the version selection menu, you need to select the version with the prefix + GFun
In the update with a single button in the brand name there is such a prefix, there you need to press the red triangle and scroll up or select the desired version of the brand.
DiagBaseServiceAp (this application is needed for encoding) is downloaded simultaneously with the marks in the Downloads folder, it needs to be installed from there manually
After downloading everything, we make a backup (a copy of your software for the ability to restore it).
After you download all the marks on the device, do not forget to save the folder "XDIAGPRO". It can be stored on your computer and on the cloud, so as not to lose. And also it is necessary to save the application itself
If something happens to the phone / tablet, you can easily restore all activation using this folder.
To restore to another device, you need to insert the saved folder "XDIAGPRO" there and over install my application
To transfer stamps to a flash card, you can use third-party programs.
email endru.norton7@yandex.ru
Type de fichier : jpg 6f47c404k1f7-1920.jpg (60,1 Ko, 117 affichages)
enteran est déconnecté   Réponse avec citation
The Following 21 Users Say Thank You to enteran For This Useful Post:
alinjadii (25/10/2018), autodesign 67 (17/04/2019), autoscan (09/09/2018), brahimlamgarbi (18/10/2018), bzkmatrix (02/10/2021), diago2001 (04/11/2018), ElTurco (18/11/2022), izouf (09/10/2018), lutti68 (25/08/2020), micka45 (18/10/2018), nasisamy (04/09/2021), pipet (05/08/2019), rapou30 (16/02/2019), reda75 (15/10/2019), saadousfar (21/07/2020), selouan (14/08/2018), thomas (25/10/2018), xdols (14/08/2018), yoyomartin2003 (20/08/2018), zagor (10/12/2018)
