Discussion: Aide pour log erreurs
Vieux 23/08/2018, 10h35
sami_b
Avatar de sami_b
sami_b is an unknown quantity at this point
Par défaut Aide pour log erreurs
Bonjour Je viens de faire un scan complet et voici le log des erreurs
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AK HW: 3C0 614 109 AK
Component: J104 C4 440 V2 0027
Revision: --025--- Serial number: 00000705619431
Coding: 0035311
Shop #: WSC 00028 790 00002
VCID: 67DA60DE56F6947948-8032
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 71
Mileage: 166828 km
Time Indication: 0
Date: 2013.01.06
Time: 1154
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 163
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00028 028 00022
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 7DF622B6EC6A2EA982-8028
1 Fault Found:
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 22
Reset counter: 43
Mileage: 166424 km
Date: 2018.06.26
Time: 1133
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08791012036875
Coding: 100002
Shop #: WSC 00028 028 00001
VCID: 326CC18A6DB421D12F-8066
2 Faults Found:
02070 - Rear Parking Aid Sensors
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 166424 km
Time Indication: 0
Date: 2012.11.16
Time: 10:23:56
Freeze Frame:
Temperature: 31.0�C
02069 - Front Parking Aid Sensors
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 166424 km
Time Indication: 0
Date: 2012.11.16
Time: 10:23:56
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 872 G HW: 3C0 920 872 G
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 160F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
VCID: 295E26E6486262099E-807C
1 Fault Found:
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 166424 km
Date: 2018.06.26
Time: 11:09:00
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 7AFC29AA35441991A7-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 2
Reset counter: 47
Mileage: 166427 km
Time Indication: 0
Date: 2012.11.25
Time: 00:00:43
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0305
Revision: 12101005 Serial number: 0000871874
Coding: 0210B7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 26442DDA597C4D71B3-8072
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0402
Serial number: 00000001461478
Coding: 000090
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 74
66561 - Motor for mirror fold-in
B11F6 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 70
Mileage: 166337 km
Date: 2018.06.04
Time: 07:34:03
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.147 0703
Revision: 1AH03726 Serial number: 00101230108101
Coding: 0000258
VCID: 3A7CE9AA75C4D991E7-806E
1 Fault Found:
01288 - Terminal 30; Steering Assist
Freeze Frame:
Fault Priority: 9
Fault Frequency: 1
Reset counter: 45
Mileage: 166425 km
Time Indication: 0
Date: 2012.11.25
Time: 00:00:01
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 2.0
Voltage: 12.30 V
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 A HW: 3C0 959 792 A
Component: TUER-SG BT 002 0305
Revision: 14101005 Serial number: 0000864696
Coding: 0210B6
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 275A20DE5E76547988-8072
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0402
Serial number: 00000001459122
Coding: 000090
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 74
Envoyé de mon SM-N9005 en utilisant Tapatalk
---------- Post added at 09h35 ---------- Previous post was at 09h33 ----------
Je suis encore bleu et je m adresse a vous pour m aider a décrypter les erreurs
sami_b est déconnecté   Réponse avec citation
