Discussion: probleme fusilble
Vieux 26/08/2018, 14h18
Mehdi13
Avatar de Mehdi13
Mehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud ofMehdi13 has much to be proud of
J'AI CHERCHER AU NIVEAU DE LA GROSSE PRISE ENTRE HABITACLE ET COMPARTIMENT MOTEUR LE FIL QUI ARRIVE DE LA GROSSE PRISE DÉMARRE AVEC 2 PETITS FILS ROUGE UN PART AU BOITIER UCH LE 2EME PART AU LECTEUR DE CARTE J'AI OUVERT LES 2 BOÎTIERS pas UNE TRACE NICKEL
CA C'EST COTE HABITACLE PAR CONTRE SE LUI QUI DÉMARRE DE LA BOITE A FUSIBLE A 2 FILS UN VA COTE HABITACLE L'AUTRE J'AI TROUVER ENCORE OU
IL VA.!!
POUR INFO QUAND JE DÉBRANCHE TOUT JE REMET UN FUSIBLE ELLE REDÉMARRE JE L'AI LAISSER 1 HEURE ENTRAIN DE TOURNER JE L’ÉTEINS
1/2 HEURE JE LOUVRE Y A TOUT QUI BUG RIEN NE FONCTIONNE MÊME PAS LA CARTE J’ENLÈVE LA COSSE FUSIBLE PETER TU REMET UN AUTRE PÈTE
VOILA CE QU'ELLE FAIT ..!!!
Mehdi13 est déconnecté   Réponse avec citation
