Vieux 26/09/2018, 14h35
fedge
Avatar de fedge
Pouvoir de réputation: 30
fedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud offedge has much to be proud of
Salut.
Je comprends pas. 0 ohm c' est un court circuit. Tu as un court circuit ou un circuit ouvert ?? Si le can est débranché coté bsi et que tu mesures la ligne, c' est pas le bsi qui pose problème . C' est la dae ( si elle est branchée ??) car tu devrais avoir 120 ohms.
Ton histoire ressemble plus a une batterie inversée qu' a un amorçage sur la carcasse du calculateur.
fedge est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to fedge For This Useful Post:
ABDOULUX (26/09/2018), rotax (26/09/2018), soustourou (26/09/2018), Y.B tec (27/09/2018)
