Discussion: Info bios
Vieux 10/10/2018, 20h50
khoums
Avatar de khoums
khoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to allkhoums is a name known to all
Essaie ça
.On boot screen Press F2. You must be in Bios Setup Screen which is (Phoenix SecureCore(tm) Setup Utility)
Attempt to login using this passwords: "3hqgo3", "jqw534", "0qww294e" (Do not enter again passwords until you get master password)
If a Master Password is displayed copy it and use this windows binary script sites.google.com/site/dogber1/blag/pwgen-fsi-5x4dec.zip or using this website bios-pw.org/ Enter the Hash Codes
On the Master Password Input Box use the decrypted code if you use the online site use the Fujitsu-Siemens
You should be able to access the bios screen and change the settings make sure to remove the Password on Hard Disk and Supervisor Password
Use the Decrypted hash code as your current password To Clear the Supervisor Password
Envoyé de mon BLA-L29 en utilisant Tapatalk
LES COÏNCIDENCES SONT UNE MANIÈRE POUR DIEU DE RESTER ANONYME.
Albert EINSTEIN
khoums est déconnecté   Réponse avec citation
The Following User Says Thank You to khoums For This Useful Post:
safi.mecashop (10/10/2018)
