Vieux 16/10/2018, 22h02
YUMBO
Avatar de YUMBO
Pouvoir de réputation: 23
YUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud ofYUMBO has much to be proud of
A ta place, je boucherais les quatre tuyaux d'injecteur, ATTENTION, J AI BIEN DIT LES TUYAUX ET NON LA SORTIE DE POMPE HP, et sous l'action du démarreur, vérifie ta pression de rampe, si la pression monte au mini 300 B, alors tu as trop de retour sur tes injecteurs
YUMBO est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to YUMBO For This Useful Post:
mechatronik_algerie (17/03/2019), soustourou (16/10/2018), zingilingiling (16/10/2018)
