Vieux 17/10/2018, 19h19
enteran
Avatar de enteran
enteran has a spectacular aura aboutenteran has a spectacular aura about
DANGER! NEW PROTECTION EASYDIAG 3.0
https://yadi.sk/d/pGQTk2bKrrJz1A
---------- Post added at 08:17 PM ---------- Previous post was at 08:09 PM ----------
Envoyé par enteran Voir le message
Inside the board are glued to the case. When opened, the adhesive removes the parts from the boards. It is necessary to enlighten the body with a bright light. See where the glue is. Heat the body, it will help. You can cut the area with glue. Black resin on the contacts for programming is removed when heated.
---------- Post added at 08:19 PM ---------- Previous post was at 08:17 PM ----------
[QUOTE=enteran;641149]DANGER! NEW PROTECTION EASYDIAG 3.0
https://yadi.sk/d/pGQTk2bKrrJz1A[COLOR="Silver"]
enteran est déconnecté   Réponse avec citation
The Following User Says Thank You to enteran For This Useful Post:
REDZONE31 (18/10/2018)
