Discussion: cheksum verification
Vieux 23/12/2018, 16h59
oumanni65
Avatar de oumanni65
oumanni65 will become famous soon enough
Envoyé par oumanni65 Voir le message
si j'avais le meme probleme et sur la 2eme carte c'est juste des petites modifs pour les crackls donc ca vien pas de ca
voila des logs pression et débitmètre , et vu que j'ai une admission direct j'entend comme une fuite(pshiit) en acceleration comme si la DV laisse passer de la pression en continu , je l'ai deja testé et la menbrane fait son role ,,,
Sunday,23,December,2018,1618:00006-VCID:7F0DB5FE2DFD7ABC61-515A,VCDS Version: Release 18.2.0,Data version: 20180212 DS287.0
8E0 909 518 AQ,ADVMB,1.8L R4/5VT G 0010,
,,G002,F3,G006,F2,G115,F2,G115,F3,G000,F0,G000,F0, G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Group 2 - Field 3,TIME,Group 6 - Field 2,TIME,Group 115 - Field 2,TIME,Group 115 - Field 3,,,,,,,,,,,,,,,,,
,STAMP,Mass Air Flow - Sensor (G70),STAMP,Intake Air - Temperature (G42),STAMP,Boost Pressure - (specified),STAMP,Boost Pressure - (******),,,,,,,,,,,,,,,,,
,, g/s,,°C,, mbar,, mbar,,,,,,,,,,,,,,,,,
,0.01,6.14,0.17,34.0,0.34,980.0,0.34,980.0,,,,,,,, ,,,,,,,,,
,0.52,18.64,0.70,34.0,0.87,2500.0,0.87,1040.0,,,,, ,,,,,,,,,,,,
,1.05,40.92,1.22,34.0,1.39,2480.0,1.39,1330.0,,,,, ,,,,,,,,,,,,
,1.56,57.72,1.73,33.0,1.90,2470.0,1.90,1660.0,,,,, ,,,,,,,,,,,,
,2.07,82.83,2.25,33.0,2.42,2470.0,2.42,2070.0,,,,, ,,,,,,,,,,,,
,2.59,107.72,2.76,34.0,2.93,2450.0,2.93,2320.0,,,, ,,,,,,,,,,,,,
,3.10,125.97,3.27,34.0,3.45,2470.0,3.45,2410.0,,,, ,,,,,,,,,,,,,
,3.62,135.36,3.80,35.0,3.98,2470.0,3.98,2370.0,,,, ,,,,,,,,,,,,,
,4.15,142.78,4.32,36.0,4.49,2450.0,4.49,2330.0,,,, ,,,,,,,,,,,,,
,4.66,145.83,4.84,38.0,5.01,2380.0,5.01,2300.0,,,, ,,,,,,,,,,,,,
,5.18,151.19,5.36,39.0,5.54,2390.0,5.54,2210.0,,,, ,,,,,,,,,,,,,
,5.71,155.00,5.88,42.0,6.05,2380.0,6.05,2130.0,,,, ,,,,,,,,,,,,,
,6.23,159.47,6.40,44.0,6.57,2280.0,6.57,2060.0,,,, ,,,,,,,,,,,,,
,6.73,163.11,6.92,46.0,7.10,2150.0,7.10,1990.0,,,, ,,,,,,,,,,,,,
,7.27,164.83,7.44,48.0,7.60,1690.0,7.60,1930.0,,,, ,,,,,,,,,,,,,
,7.77,164.83,7.95,51.0,8.13,1480.0,8.13,1770.0,,,, ,,,,,,,,,,,,,
,8.29,146.58,8.47,52.0,8.66,1530.0,8.66,1490.0,,,, ,,,,,,,,,,,,,
,8.82,136.81,8.99,54.0,9.17,1510.0,9.17,1510.0,,,, ,,,,,,,,,,,,,
,9.34,141.81,9.51,54.0,9.68,1480.0,9.68,1480.0,,,, ,,,,,,,,,,,,,
,9.85,142.42,10.03,55.0,10.19,1450.0,10.19,1490.0, ,,,,,,,,,,,,,,,,
,10.36,143.58,10.56,56.0,10.72,1460.0,10.72,1460.0 ,,,,,,,,,,,,,,,,,
,10.89,142.22,11.07,56.0,11.24,980.0,11.24,1310.0, ,,,,,,,,,,,,,,,,
,11.42,11.94,11.59,54.0,11.78,980.0,11.78,1100.0,, ,,,,,,,,,,,,,,,
,11.94,14.06,12.12,51.0,12.29,980.0,12.29,1060.0,, ,,,,,,,,,,,,,,,
,12.45,12.31,12.63,50.0,12.80,980.0,12.80,1040.0,, ,,,,,,,,,,,,,,,
,12.98,12.28,13.16,49.0,13.34,980.0,13.34,1030.0,, ,,,,,,,,,,,,,,,
,13.51,12.17,13.67,48.0,13.84,980.0,13.84,1020.0,, ,,,,,,,,,,,,,,,
,14.01,12.14,14.19,47.0,14.36,980.0,14.36,1020.0,, ,,,,,,,,,,,,,,,
,14.53,11.50,14.71,45.0,14.89,980.0,14.89,1020.0,, ,,,,,,,,,,,,,,,
,15.06,11.53,15.23,45.0,15.40,980.0,15.40,1010.0,, ,,,,,,,,,,,,,,,
oumanni65 est déconnecté   Réponse avec citation
