Discussion: cheksum verification
Vieux 25/12/2018, 02h28
oumanni65
Avatar de oumanni65
oumanni65 will become famous soon enough
Envoyé par brino Voir le message
Quand tu logue ajoute le canal 3 au canal choisi sa te permettra d<;'avoir une idéee aproximative des rpm
Ta voiture en origine a t'elle le défaut de pression ?
Salut l'ami , oui j'avais ce probleme meme avant , c'est vrai que j'ai oublier le rpm voici un log mais en point mort
Monday,24,December,2018,17:05:01:00006-VCID:7F0DB5FE2DFD7ABC61-515A,VCDS Version: Release 18.2.0,Data version: 20180212 DS287.0
8E0 909 518 AQ,,1.8L R4/5VT G 0010,
,Group A:,'115,,,,Group B:,'003,,,,Group C:,'106
,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,Engine Speed,Mass Air Flow,Throttle Valve Angle,Ignition,, , , ,
,TIME,(G28),,(specified),(******),TIME,(G28),Senso r (G70),,Timing Angle,TIME,,,,
Marker,STAMP, /min, %, mbar, mbar,STAMP, /min, g/s, %, °BTDC,STAMP,,,,
,0.49,720,20.3,990.0,990.0,0.14,720,2.92,1.6,5.3,0 .31, , , ,
,1.01,720,19.5,990.0,990.0,0.66,720,2.92,1.6,6.8,0 .83, , , ,
,1.51,1360,66.9,1410.0,970.0,1.18,720,4.97,5.5,21. 0,1.34, , , ,
,2.02,3960,88.0,2500.0,1140.0,1.68,2120,26.61,74.5 ,12.8,1.85, , , ,
,2.54,6600,72.2,990.0,1750.0,2.20,5000,117.92,100. 0,14.3,2.38, , , ,
,3.06,5760,15.0,990.0,1160.0,2.72,6320,8.00,7.5,0. 0,2.89, , , ,
,3.58,4960,14.3,990.0,1070.0,3.23,5480,14.86,9.4,-1.5,3.40, , , ,
,4.09,4240,14.3,990.0,1040.0,3.75,4720,12.94,8.2,-3.0,3.91, , , ,
,4.62,3560,14.3,990.0,1020.0,4.27,4000,11.36,7.5,-3.8,4.44, , , ,
,5.14,3080,15.0,990.0,1010.0,4.79,3360,9.53,6.3,0. 0,4.96, , , ,
,5.65,2640,15.0,990.0,1000.0,5.30,2960,8.69,5.5,2. 3,5.47, , , ,
,6.19,2160,15.0,990.0,1000.0,5.83,2480,7.08,4.3,2. 3,6.00, , , ,
,6.71,1680,14.3,990.0,1000.0,6.36,2040,5.92,3.5,0. 0,6.53, , , ,
,7.22,1240,15.8,990.0,990.0,6.88,1520,4.06,2.0,-4.5,7.05, , , ,
,7.73,1040,14.3,990.0,990.0,7.39,1200,3.44,1.6,4.5 ,7.57, , , ,
,8.26,880,15.0,990.0,990.0,7.92,1000,2.92,1.2,12.8 ,8.08, , , ,
,8.76,760,18.0,990.0,990.0,8.42,800,2.97,1.6,12.8, 8.59, , , ,
oumanni65 est déconnecté   Réponse avec citation
