Discussion: cheksum verification
Vieux 25/12/2018, 19h03
oumanni65
Avatar de oumanni65
oumanni65 will become famous soon enough
Envoyé par oumanni65 Voir le message
Salut l'ami , oui j'avais ce probleme meme avant , c'est vrai que j'ai oublier le rpm voici un log mais en point mort
Monday,24,December,2018,17:05:01:00006-VCID:7F0DB5FE2DFD7ABC61-515A,VCDS Version: Release 18.2.0,Data version: 20180212 DS287.0
8E0 909 518 AQ,,1.8L R4/5VT G 0010,
,Group A:,'115,,,,Group B:,'003,,,,Group C:,'106
,,Engine Speed,Engine Load,Boost Pressure,Boost Pressure,,Engine Speed,Mass Air Flow,Throttle Valve Angle,Ignition,, , , ,
,TIME,(G28),,(specified),(******),TIME,(G28),Senso r (G70),,Timing Angle,TIME,,,,
Marker,STAMP, /min, %, mbar, mbar,STAMP, /min, g/s, %, °BTDC,STAMP,,,,
,0.49,720,20.3,990.0,990.0,0.14,720,2.92,1.6,5.3,0 .31, , , ,
,1.01,720,19.5,990.0,990.0,0.66,720,2.92,1.6,6.8,0 .83, , , ,
,1.51,1360,66.9,1410.0,970.0,1.18,720,4.97,5.5,21. 0,1.34, , , ,
,2.02,3960,88.0,2500.0,1140.0,1.68,2120,26.61,74.5 ,12.8,1.85, , , ,
,2.54,6600,72.2,990.0,1750.0,2.20,5000,117.92,100. 0,14.3,2.38, , , ,
,3.06,5760,15.0,990.0,1160.0,2.72,6320,8.00,7.5,0. 0,2.89, , , ,
,3.58,4960,14.3,990.0,1070.0,3.23,5480,14.86,9.4,-1.5,3.40, , , ,
,4.09,4240,14.3,990.0,1040.0,3.75,4720,12.94,8.2,-3.0,3.91, , , ,
,4.62,3560,14.3,990.0,1020.0,4.27,4000,11.36,7.5,-3.8,4.44, , , ,
,5.14,3080,15.0,990.0,1010.0,4.79,3360,9.53,6.3,0. 0,4.96, , , ,
,5.65,2640,15.0,990.0,1000.0,5.30,2960,8.69,5.5,2. 3,5.47, , , ,
,6.19,2160,15.0,990.0,1000.0,5.83,2480,7.08,4.3,2. 3,6.00, , , ,
,6.71,1680,14.3,990.0,1000.0,6.36,2040,5.92,3.5,0. 0,6.53, , , ,
,7.22,1240,15.8,990.0,990.0,6.88,1520,4.06,2.0,-4.5,7.05, , , ,
,7.73,1040,14.3,990.0,990.0,7.39,1200,3.44,1.6,4.5 ,7.57, , , ,
,8.26,880,15.0,990.0,990.0,7.92,1000,2.92,1.2,12.8 ,8.08, , , ,
,8.76,760,18.0,990.0,990.0,8.42,800,2.97,1.6,12.8, 8.59, , , ,
bON LES AMIS j'ai fait un test avec la durite wastegate debrancher la voiture reagi mieux j'ai pas trop accelerer et meme ca j'avai le code error comme pression trop elever donc j'ai pretet la N75 d'un amis qua une s3 et j'ai fait ces logs
Type de fichier : jpg LOG1.jpg (98,2 Ko, 3 affichages)
Type de fichier : jpg LOG2.jpg (97,2 Ko, 3 affichages)
oumanni65 est déconnecté   Réponse avec citation
