Vieux 29/12/2018, 12h50
wscar
Avatar de wscar
wscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to behold
Determining IMMO-ID & VIN (ECU)
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID..
[Done, Go Back]
[Close Controller, Go Back - 06]
Determining IMMO-ID & VIN (Instrument Cluster)
[Select]
[25 - Immobilizer]
[Meas. Blocks - 08]
Select Block 081.
[Go!]
[Done, Go Back]
Instrument Cluster Swapping (Used Cluster)
Prerequisites:
The NEW (USED) cluster is installed in the car.
Battery voltage at least 12.0 V.
All relevant coding and adaptation values have been transferred from the OLD (ORIGINAL) cluster to the NEW (USED) cluster.
Make sure to have BOTH PIN's, from the OLD (ORIGINAL) and the NEW (USED) instrument cluster.
Make sure to have the Radio Code (for factory radios only).
[Select]
[25 - Immobilizer]
[Security Access - 16]
For the following procedure, use the PIN of the NEW (USED) instrument cluster.
4-digit PIN
Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
[Do it!]
The instrument cluster now shows Immobilizer Adaptation active, wait until it changes to Immobilizer active - this may take up to 2 Minutes.
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
For the following procedure, use the PIN of the OLD (ORIGINAL) instrument cluster.
4-digit PIN
[Test]
[Save]
[Done, Go Back]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Verify that the NEW (USED) instrument cluster now shows the VIN/IMMO-ID of the vehicle now.
Voila la procedure au vcds extrait de leur site suit la a la lettre et sa fonctionneras.
---------- Post added at 12h50 ---------- Previous post was at 12h46 ----------
Ensuite il te resteras a faire apprentissage fes cleeset ca seras good!
Si j ai peu aider n oubliez pas de cliquer sur THANKS!
wscar est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to wscar For This Useful Post:
alinjadii (29/12/2018), car83 (29/12/2018), DIAGSYSTEM25 (29/12/2018), khoums (29/12/2018), pouettedu76 (08/01/2020)
