Vieux 02/01/2019, 21h32
hatem006
Avatar de hatem006
Pouvoir de réputation: 22
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
merci zenata,enfait je suis sur d'utiliser le bon calculo,j'arrive a se connecter avec écu moteur sans adaptateur,écu abs et direction assisté avec adaptateur vert comme me demande le soft,mais tous les autres ecu pas d'adaptateur a utiliser mais j'arrive pas a se connecter non plus voila la liste
Bosch EDC16C39 CF5 / EOBD Injection diesel (1.6, 1.9, 2.0) | INFO | DTC | DTC EX | PRM | ACT | ADJ | KL ELM
Marelli SELESPEED CFC300 Boîte de vitesses automatique | INFO | DTC | DTC EX | PRM | ACT | ADJ | KL ELM
Bosch ABS 8 | INFO | DTC | DTC EX | PRM | ACT | ADJ | KL ELM A1 P1
Bosch ABS 8 ASR | INFO | DTC | DTC EX | PRM | ACT | ADJ | KL ELM A1 P1
Bosch ABS 8 VDC | INFO | DTC | DTC EX | PRM | ACT | ADJ | KL ELM A1 P1
airbag continental (PROXI) | INFO | DTC | DTC EX | PRM | ELM
Siemens Airbag MY06 | INFO | DTC | DTC EX | PRM | ACT | ORME
Direction assistée électrique TRW (3) | INFO | DTC | PRM | ADJ | KL ELM A1 P9
réinitialisation de l'intervalle de service | INFO | ADJ | ELM
Connect (NAV) Marelli | INFO | DTC | PRM | ACT | ADJ | ELM
Convergence Lauberhorn C1 (Blue & Me Nav) | INFO | DTC | Convergence ELM
Marelli / Microsoft (Blue & Me) | INFO | DTC | Convergence ELM
Marelli / Microsoft C3 (Blue & Me Nav) | INFO | DTC | Tableau de
bord ELM Marelli | INFO | DTC | PRM | ACT | ADJ | ELM
Radio Nav Marelli | INFO | DTC | PRM | ACT | Ordinateur de corps ELM
Marelli (198) | INFO | DTC | PRM | ACT | ADJ | ELM
CAN Info| INFO | Moniteur / paramètres du véhicule CAN ELM | DTC | PRM | ADJ | Procédure d'alignement CAN Setup / PROXI | INFO | ADJ | Contrôle climatique ELM Marelli | INFO | DTC | DTC EX | PRM | ACT | ADJ | ELM Litronic lampe frontale XENON ( à gauche) | INFO | DTC | PRM | ACT | ADJ | KL ELM A1 P12 Litronic Lampe frontale XENON (droite) | INFO | DTC | PRM | ACT | KL ELM A1 P12 Siège du conducteur LEAR | INFO | DTC | Contrôle de stationnement ELM Bosch | INFO | DTC | PRM | ADJ | Siège de passager ELM LEAR | INFO | DTC | Contrôle de la pression des pneus ELM (TPMS) TRw
| INFO | DTC | DTC EX | PRM | ACT | ADJ | KL A4 P13
du coup y'a que l'abs et la direction assisté qui demande un adaptateur qui le A1( le vert)
---------- Post added at 09:32 PM ---------- Previous post was at 09:30 PM ----------
zenata peut-tu regarder sur wow si on peut faire l'alignement de proxy pour bravo 2009
merci 5ouya
hatem006 est déconnecté   Réponse avec citation
