Discussion: touran demarre plus
Vieux 03/01/2019, 18h32
nas33
Avatar de nas33
Pouvoir de réputation: 24
nas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to beholdnas33 is a splendid one to behold
Par défaut touran demarre plus
bonjour j ai acheter touran 2L 140 2003 ET IL DEMARRE PLUS IL C ARRETER D UN COUP .J AI PASSER VCDS ET J AI DEFAUT TUBURLURE D ADMISSION AVEC DEFAUT VENTILO MOTEUR DEFAUT CONNU MAIS QUI N EMPECHE PAS DE DEMARRER APRES J AI DEFAUT ABSCENSE SIGNAL AAC G40 ET DEFAUT BOUGIE PRECHAUFFAGE 2 3 4 DEFAUT CIRCUIT ELECTRIQUE. D APRES C QUE J AI VU SUR FORUM LE CAPTEUR ACC N EMPECHE PAS DE DEMARRER .AVEC VCDS DANS PARAMETRE J AI DU MAL A COMPRENDRE LE PARAMETRE COMME PRESSION GAZOIL LA SYCRO AAC VILO ET AUSSI POMPE GAVAGE FONCTIONNE.SI QLQ1 A UNE IDDEE MERCI BONNE ANNEE
nas33 est déconnecté   Réponse avec citation
