Vieux 03/01/2019, 21h08
souague
Avatar de souague
souague is a jewel in the roughsouague is a jewel in the roughsouague is a jewel in the rough
Envoyé par Simple Voir le message
However, "Data Access Problem" is related to missing or disconnected hardware (like network card) or improperly installed drivers. The network card does not need to be connected to the internet, but it should be working and possible o connect.
Yes
It could also be related to a failing service due to missing / corrupt / wrong version files, for example having 2 versions of Java !!
I think the os doesn't support the installation of two different versions of java.
Yes, I had read your work about it but I didn't try. I mainly use diagbox under windows 7 x86 on another partition.
---------- Post added at 21h08 ---------- Previous post was at 21h04 ----------
The updates are less problematic.
souague est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to souague For This Useful Post:
Heineken (03/01/2019), manudiag (04/01/2019)
