Vieux 07/01/2019, 19h01
zenata
Avatar de zenata
Pouvoir de réputation: 174
airbag continental (PROXI) | INFO | DTC | DTC EX | PRM | ELM
Siemens Airbag MY06 | INFO | DTC | DTC EX | PRM | ACT | ORME
|INFO| - Identification data reading is supported on the module
|DTC| - Error codes reading and clearing is supported on the module
|DTC EX| - Error code details reading is supported on the module
|PRM| - Parameter reading is supported on the module
|ACT| - Actuator functions are supported on the module
|ADJ| - Adjustment procedures are supported on the module
tu n'a pas ADJ , donc tu pourras pas coder ou paramétrer
ton calculo airbag
ni avec multiecuscan , ni wow , ni delphi
---------- Post added at 19h01 ---------- Previous post was at 18h56 ----------
tu peux alignement proxy oui , tu peux avec les 3 softs
dans calculo body (carrosserie)
hatem006 (19/01/2019)
