Vieux 08/01/2019, 22h03
hatem006
Avatar de hatem006
Pouvoir de réputation: 22
hatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud ofhatem006 has much to be proud of
airbag continental (PROXI) | INFO | DTC | DTC EX | PRM | ELM
Siemens Airbag MY06 | INFO | DTC | DTC EX | PRM | ACT | ORME
|INFO| - Identification data reading is supported on the module
|DTC| - Error codes reading and clearing is supported on the module
|DTC EX| - Error code details reading is supported on the module
|PRM| - Parameter reading is supported on the module
|ACT| - Actuator functions are supported on the module
|ADJ| - Adjustment procedures are supported on the module
tu n'a pas ADJ , donc tu pourras pas coder ou paramétrer
ton calculo airbag
ni avec multiecuscan , ni wow , ni delphi
---------- Post added at 19h01 ---------- Previous post was at 18h56 ----------
tu peux alignement proxy oui , tu peux avec les 3 softs
dans calculo body (carrosserie)
merci zenata mais mon problème c'est que j'arrive juste a lire INFO avec alfaobd cetout mais sinon meme avec alfaobd et multiecuscan pas de DTC | DTC EX | PRM | ACT | ORME TOUT SIMPLEMENT PARCE QUE JE ME CONNECTE PAS AVEC ECU( PROBLEME DE COMMUNICATION ECU) POURTANT AVEC DELPHI JE ME CONNECTE A TOUS ECU SANS PROBLEME
hatem006 est déconnecté   Réponse avec citation
