Vieux 18/01/2019, 08h54
AME
Avatar de AME
Quelles valeurs lues, en paramètre, avec VCDS ??
Je viens de lancer une regeneration en manuelle
08h22
81471.70 s Particle filter; time since last regeneration 120
0 hPa Particle filter; differential pressure; dynamic offset 121
7 Particle filter; field regeneration request status 122
00000000 Particle filter; field regeneration lock status 123
952.3 km Particle filter; kilometers since last regeneration 124
57.08 l Particle filter; fuel consumption since last regeneration 125
0.0000000 g Particle filter; oil ash volume 126
-0.91 g Particle filter; soot mass measured 127
172.8000 s Service regeneration; current duration 140
148.91 °C Exhaust gas temperature sensor 4 424
25.04 hPa Particle filter; difference pressure 495
24.14 g Particle filter; soot mass calculated 496
12 minutes plus tard
08h34
82196.90 s Particle filter; time since last regeneration 120
8 Particle filter; field regeneration request status 122
57.84 l Particle filter; fuel consumption since last regeneration 125
893.1000 s Service regeneration; current duration 140
557.10 °C Exhaust gas temperature sensor 4 424
55.06 hPa Particle filter; difference pressure 495
23.78 g Particle filter; soot mass calculated 496
Finalement , c'est la valeur "-0.91 g Particle filter; soot mass measured 127" que je ne comprend pas . Elle n'a pas bougé d'un poil. Moteur arrête, j'ai la même valeur. Alors que la valeur " Particle filter; difference pressure" evolue bien
